Bush Swamper 16/24 wheeler.
  • #31
    bushswamper
    where are you located Have a tank and other stuff
    • #32
      Grizzly 24 Wheeler Parts
      Well, still working on my rebuild. Replaced rusted corrugated steel floorboards with 1/8" aluminum diamond plate. Reglassing the hood and dash. Rebuilt carb and fuel pump. I still need to make the steering brake pushrods. I know they are spring-loaded telescoping. Does any one know what the compressed and relaxed lengths of these assembly's are? I also am looking for some new wheels. The previous owner drove it with the inside tires flat which destoyed the bead. Also looking for the steering brake pads and seals. I'm located north of Chicago. Thank you, Metalstech
      • #33
        I have an excellent Bush Swamper. What did you need to know?
        • #34
          Hi Pvanlov I was wondering if you have a service manual and operators manual for the bush swamper. I just bought one last weekend and could use some info on how it drives and stuff.
          thanks
          • #35
            thanks
            Any Pics? I am always looking to buy one.
            • #36
              Hey there Pvanloy, I am a machinist by trade, so making parts is my life. What I could use are the dimensions for the steering brake spring loaded pushrods. I remained the corroded piston bores and resleeved them with 4.625 " OD x 4.5" steel cylinders. Now I am trying to locate new wheels, 8x8.5" 5/4.5" bolt pattern. Almost ready to ride.
              • #37
                I own two of these machines
                • #38
                  Any pictures, or thoughts on them? I've always wanted one they seem like a good idea.
                  • #39
                    i would enjoy seeing either some pics or sketches of how the drive train works ...trans, belts chains etc. if anyone of the owners gets a chance. just fun to see the design of how they are built......johnboy va.
                    • #40
                      This thread is useless....without....pictures
                      MUSCATEER 6x6
                      MUSCA TUR BOTA then eh?
                      94 F350 4x4 7.3 IDI ZF 5sp
                      Al "Camo pants"
                      • #41
                        those 2 videos on the net...the yellow one he is driving in the snow and the other where he is hauling out the moose and then the trailer are pretty impressive. i still can't figure out looking at the machine how the axles are supported. looks like there is only a maybe 6'' wide center down the bottom side of the tub that the axles go in. a max or argo have 2 axle bearings spaced about 12'' apart to support the axle.... how are those bush swamper axles supported...anyone ? johnboy va.
                        • #42
                          Agreed it seems these Bushswampers are very photo shy.
                          • #43
                            would you happen to have a service manual?
                            • #44
                              The axels are supported from the inside. The Axels are hollow with a tube inside. So they can turn opposite each other for turning
                              • #45
                                5 Pages and still no pics!??
                                I'll fix that right now... (many pics attached)
                                I recently bought this thing for $1500. Not cus I need it for anything.. just cuz I'm thrilled that someone actually thought up the concept and went ahead and built the darn thing. Gotta love the 70's!!
                                I only put about a mile on it before I decided it would be neat to do a 360 by reversing the transmissions like the guy on Youtube. I should have read the dash-plaque first that warns against this (unless on snow/ice like buddy was). So now I have a broken chain to figure out how to replace. I know I didnt break the gearbox cuz the front axle still drives on the broken side.. just the rest jam up if I roll it a foot or two forward then back. I also broke the throttle cable a few minutes later, so thats enough headache for one day.
                                I'll maybe start a new thread when I get in to it and take pics of the inner workings. I dont have a manual.. nor access to the shop foreman as mentioned earlier in this thread, LOL.
                                I worked at Argo and have had several over the years and let me tell you.. this is nothing like an Argo!! Driving it is like rubbing your belly and patting your head at the same time.. dam near impossible.
                                The drive clutches are not centrifugal like a snowmobile. You engage them by pulling the steering column towards you. As you speed up, the secondaries start to function and you can pull back even farther to use them fully.
                                The brakes on mine appear to be nothing more than brake liner attached to flexible food-pads. Though this is not a skid steer machine, I suspect applying brake pressure on one side while steering might come close to a skid steer effect.
                                Speaking of steering, get this, turning the "wheel" just disengages the associated primary clutch on that side of the engine. That's it!! Hilarious
                                I kept trying to turn harder as if to apply a brake like an Argo. That does nothing. You just have to wait for the thing to start turning. It does turn, but this is not for tight turns in the forest. Fine for me.. I just want to run it from my house to the river a mile or so away and arrive like a rock star!
                                I live in London, Ontario, if anyone has one nearby and could let me copy a manual or learn from your knowledge. Cheers! Sean
