Frustrated with my Scrambler
OK, I bought a used scrambler; vanguard 16 started and ran good, but no drive belt. Prior owner was not honest with me, but I won’t rehash that. I put a belt on it, ran good in a straight line, but wouldn’t turn. I tightened compression spring nuts to add pressure to the clutch plates but still not enough. The “engaged” clutch plate just sits there and spins till it smokes. OK, after reading all-things-scrambler on this site and anywhere else, I gave in and tore it apart, ground off all the old (very little) clutch material, bought a sheet of high-friction material from McMaster-Carr:
Stock # 60895K21 HI Friction Molded Brk & Clutch Lining Sheet .55 Coefficient of Friction, 1/8" Thick, 15" X 15" In stock at $55.00 Each
and used Industrial JB WELD to apply about ten times the amount of material that was there before. Finished putting the driveline back together last night, started it up and….. it’s like I didn’t do a thing. It will go in a straight line, but as soon as you turn the wheel and all the power goes to one side, the vehicle slows and the power side starts spinning. It was dark and I didn’t have the lights hooked up yet so I didn’t take it fast yet, but if it’s like before, when your going fast, it just goes in a straight line no matter which way you steer it. I even have the compression springs tightened to the point where it’s hard to turn the steering wheel.
HELP!!! Anyone????
Airstreamer 74
HELP!!! Anyone????
Airstreamer 74
