I am in the process of installing all new bearings on the clutch shaft of the scrambler.The smallest blind bearing that fits inside the rotor seems to have enough room for 2 sets .The shaft has enough room also.Would this be a good idea to add an extra set on each side?The blind bearing is small enough to look like a roller skate wheel bearing.The original was destroyed.The small diameter clutch shaft ends also seem long enough to support 2 sets on each side I just wonder if this would effect the moving action of the clutch-brake-or steering setup?
Double up the small blind bearings on scrambler??
I will double it up then.Originally posted by flippy View PostI am in the process of installing all new bearings on the clutch shaft of the scrambler.The smallest blind bearing that fits inside the rotor seems to have enough room for 2 sets .The shaft has enough room also.Would this be a good idea to add an extra set on each side?The blind bearing is small enough to look like a roller skate wheel bearing.The original was destroyed.The small diameter clutch shaft ends also seem long enough to support 2 sets on each side I just wonder if this would effect the moving action of the clutch-brake-or steering setup?
