Thanks for the kind words all. Noel, December (typing with fingers crossed) sounds possible, hoping to be duck hinting and flushing snipe with it come November. I joined a hunting lease about a mile from the house, which has a monster beaver pond on it. It must be around 30 acres when full and should be a good place to test this things ability. Coop, I would think the same thing except that I ordered the entire rear frame and it's related parts all new from Craig. And if you think about it, the 7 tooth would have been longer to take up the slack for the smaller diameter sprocket ( I could be wrong about that though), could I have gotten a longer track or something?
BTW you wouldn't happen to have a few pics of how the firewall and related sheet metal all fit together that you could post up would you... or send in a pm ... or email or snail mail or... Sure would be a BIG help ya know...
didn't order the firewall when he ordered the rest of the parts. This is where I'm hoping Coop is ready to offer advice... If I understand correctly, the original sheet metal served the purpose of providing ducting which allowed cool air to be drawn through the transmission cooler and to a separate central compartment. Also the parts mentioned earlier formed a similar compartment which allowed the engine to draw cool air in and also exhaust it into the central compartment. But, since I had to cut the engine cover, which creates a cool air intake for the engine and I have the necessary metal parts for the transmission cooler, plus a brand new 1800 cfm fan, My thoughts are that the other parts will only serve to congest the airflow, and are not needed. What do you guys think?
Then the worst news, cancer, a very aggressive, extremely unpredictable form, my stitches were removed, but the cut was only taped up because, instead of having that done as scheduled on the 12th, I was to have MAJOR surgery to remove about half the tissue on the back of the arm, and a signal node scan performed. Which means they inject a radioactive solution into the area nearest the site of the mole, then scan and remove the lymph nodes where the stuff shows up. I had to sit the triplets down and tell them
because it would fit so good. I came home early, excited that I had the seals I ordered and would get them put in and the hydrostats reinstalled. It should only take about 1.5 hours to pull and replace them all. I yanked them out and pulled the first of the 4 seals, cleaned the shaft oiled the lip and set it in place to drive... wait for it... too small. Yep, they are wrong. I emailed then called the guy I got them from, but he is homeward bound from Tulsa and won't be home for several hours so it will be Monday before I can get any info or order the right(hopefully) ones. But since they are out I will replace every seal I can get to on the Hydrostats and that will be that much less to worry about. Heck the machine is only 41 years old, surely they haven't changed the shaft size in such a short time.
