Occasionally I have a need to heat the odd piece of iron for bending or shaping for some project or another. The cutting torch I use is one that the wife's granddad had, I let my Dad keep my rig to use when I married and moved and just never have gotten it back. Since I have no rosebud setup on the torch here, heating a piece of iron of any size can take quite a while, and can be impossible once a certain size limit is reached. So, I started searching around and found this site, the site owner does a lot of casting parts and there is a lot of good information on the site. I just got back from the local hardware store rounding up a few pieces to build one. Thought I would link this up in case any of you might be interested in building any of the cool gadgets listed on his site for your own use. I'll take pics as I go and post them on this thread later. I think I will try building mine so that it could be dual use - like a rosebud- or mounted stationary for "forge" type work. Check out the site it's got some fun projects and a lot of useful info.
A simple homemade propane burner
So I tack welded the original one back up and re-drilled the 2nd time the RIGHT way, vise on Smithy mill, center finder, starter drill a small dimple to be certain everything was straight, then at highest speed, drill the hole.
