Hey Country Bumpkin. I've seen some of your other rides and they look sweet and awesome. Was wondering if you don't mind what you are using for the wheel hub that you build your A arms around. Looking to upgrade and adapt my old late 70's ARGO HTP to the springer style suspension and swap out the motor for not sure what yet on that. Great looking build.
New springer build
Me too! I don' like to get all greasy unless I have to.Originally posted by Andyman View PostI like your adjuster IdeaLast edited by countrybumpkin; 11-28-2015, 01:07 AM.
SGlad you like the buggies Darth I will try and get some pics tomarrow of the hubs for you.Originally posted by Darth View PostHey Country Bumpkin. I've seen some of your other rides and they look sweet and awesome. Was wondering if you don't mind what you are using for the wheel hub that you build your A arms around. Looking to upgrade and adapt my old late 70's ARGO HTP to the springer style suspension and swap out the motor for not sure what yet on that. Great looking build.
Now wait a second if your not going to build these to break i might have to change the rules. I need a fighting chance and if your stay clean too long I have no problem handing out wrenches for help on mine. LolOriginally posted by countrybumpkin View PostMe too! I don' like to get all greasy unless I have too.
Here are some pics for Darth of some springer outer bearing holders. The first one is one with bearing flanges welded to a 2" tube with 1" insert radius bearings. The second is from the Country Bumpkin which uses 1" squared shoulder insert bearings with retainer ring slipped in each end of a 2" tube. The third one is the same set up in an A arm configuration. Hope this helps.
That's great. Looks like you could have been a farmer in your past life. That's all the stuff I recognize from the farm. Simplicity takes a ton of abuse. Did you just weld the wheel hub with studs then to the end of the axle shaft after the u-joint. All the Argo parts I need and shafts and bearings are a stock item at the local bearing shop. It looks like Argo uses the simple of the shelf shafts and bearing for the old models. You seem to like the sled motors. Do you go for the water cooled or old air cooled. We have lots of selection here in Canada for that stuff. Thanks.
Ha! Yes, I live here on the old family farm. The axels are welded to the universal joints on this machine. The wheel hubs will slip on the end of the axel with a 1/4" key way and be held on with a 3/8" grade 8 bolt threaded in the end of the axel. The air cooled motors may be lighter, but if you want mega hp, liquid is the way to go. Are you racing the Argo or just want a softer ride? If you are just trail riding I would opt for a big 4 stroke.
The plan is for trail riding up in the mountains and stuff around here. There is no racing here that I know of. I don't want to spend the $20,000.00 on a side by side. I would love to get this the softer rider with a newer reliable motor. I figure the transmission will take the increase in horse power its also a 2 speed tranny. What's a good 4 stroke to jam in their. I just loaded up 1949 Ford F1 as well thats on the list for 390 and new axles. Lots a projects for the winter. I'll start a thread up for the ARGO build as well I might throw the pictures up as well that I have of the plow I built for it out of a old hot water tank.
Hey Country Bumpkin. I found the Vanguard 570CC 30 H.P. on the North east legends site. That seems to show up a lot in other threads here. I might also give Whipper a call about his A arms they look like a good build and then build my own side plate to mount everything to. Or just build all my self. Gotta see what I can get at the local bearing supply place.
Well heck! It shouldn't need working on after Buddy gets done tweeking it.
