What temp should these engines run at? Mine is running very hot. I've rejetted it some but still it hot. This is in my attex. What can I do to help cool the engine down?
Clone engine running temp.
If you header wrapped the exhaust, and have good fresh cooling air in and out of the compartment. I'd rejet again. try .039" or slightly bigger ( 1.0mm to 1.05mm) Be careful going bigger than that. If you are drilling it yourself, and you go too big, you can solder it shut and start over again.
I'd also try running without the engine cover on just to make sure it's not a cooling air issue.
Header is wrapped. Air duct blowing the hot air out. So far I've jetted to .041 and the plug is still to white. Fresh air isnt a problem, put a radiator fan on my dads cover and his is the same. Going to keep rejetting until the plug looks good and then go from there.sigpic
"Air duct blowing the hot air out."
I don't know what your air mgt ducting looks like but in my opinion it is most important to provide the engine an unlimited supply of fresh INTAKE air.The hot air will find it's way out on it's own,it has no other choice since more air is comming down the line at all times.
. Just some observations I made when having issues with overheating while building my Attex project.
Joe.sigpic
