I looked into this a bit and decided to go with a Trail Tech unit. I just received it and it has not been installed. I ended up deciding on this unit: Trail Tech 752-2013 Black Vapor Stealth Computer : Amazon.com : Automotive
I managed to get it delivered for just under a hundred dollars. Does tach, vehicle speed, odometer, air temp, engine temp, trip distance and time, overall engine time, etc. Hope it works well.
What setting do you use? The 4 cyl (4stroke) setting would take 2 sparks per rpm, would you run the trigger wire long enough to trigger off BOTH spark plugs?
