tach
  • #16
    I looked into this a bit and decided to go with a Trail Tech unit. I just received it and it has not been installed. I ended up deciding on this unit: Trail Tech 752-2013 Black Vapor Stealth Computer : Amazon.com : Automotive
    I managed to get it delivered for just under a hundred dollars. Does tach, vehicle speed, odometer, air temp, engine temp, trip distance and time, overall engine time, etc. Hope it works well.
    Thanks,
    Gary
    • #17
      Originally posted by thebuggyman1 View Post
      That's a good looking tach, and I bet it is accurate and easy to read.....BUT, I'm confused. How do you hook it up to make it read correctly?
      Even if the sense wire will trigger off a spark plug wire What setting do you use? The 4 cyl (4stroke) setting would take 2 sparks per rpm, would you run the trigger wire long enough to trigger off BOTH spark plugs?
      That is the one that I have in my Max IV:
      I think Lewis is running the same one. I don't remember what setting I used with mine but it did read correctly and it is triggered by the inductive pickup that goes around just one spark plug wire.
      • #18
        Thanks Mike. That will give me a better option for the next machine. The tiny ones work great for hourmeters, but not great as tachs.
        Here is a video of one I took for tuning the clutches
        • #19
          As Mike said it uses an iductive pick-up placed on either plug wire. Then has a simple procedure to program tach for the number of cylinders. (1-12). Few tachs will do this. Only ones that say DIS compatible. (As far as I know)
          • #20
            I find the digital tachs are hard to see in sunlight
            Heres the manual that explains the different types of connections.
            Direct hookup is best.
            • #21
              Which tach is easier to hook up...
              Autometer or
              Equis tachs
