Hi I'm kinda new to the 6x6 stuff I was wondering if it would work if I put a 2007 Polaris sportsman 450 motor in my max ll .... Any advice would be helpful thank you
Quad motor in a max ll
I think a quad motor would work great, BUT......
You would have to machine a few custom parts to get a compatible primary clutch to bolt to it. OR if it comes with a primary, use the secondary off the quad AND change the tuning and gear ratio on the machine. Just remember that the quad motor will not have the same torque as a briggs, kohler, etc. I would think it would be more like a 2 stroke, with a higher rpm limit, so just gear it down a little.
What does it do in neutral? Watch the clutches cycle when it is in neutral, and see if it cycles properly. If it is out of adjustment, or you have a clutch issue, it can put the machine in a much higher gear ratio, and you will lose a bunch of power.
If the motor starts well and runs smooth, it is doubtful that the motor is your problem. Read this: ATV and Snowmobile Belts - by Dayco
