I just got a new (old) Trackster and it just doesn't want to run. I replaced the plugs cleaned the fuel system and cleaned the carb. It has the tillotson (sp?) carb which appears to be fine. The fuel pump has what appears to be good flow.
I can get the machine to start and run but the minute you put it under load it dies. It seems to want to run on the primer too, on this motor the primer is directly into the intake not through the carb. I pulled the fuel line off the pump and ran a squirt bottle directly to the carburetor to see if that would change it and it was the same or maybe even slightly worse. Just to be safe I started putting points in it but ran out of time to finish that job tonight.
Of anyone has any idea what to do next I am all ears. I appreciate the help.
Nick
PS- I know the best thing to do is put a 4 stroke on it but that isn't going to happen this weekend. Maybe after I sell my other Trackster.
Nick
