I have a Argo response that is experiencing fuel starvation problem. The motor( Briggs 18hp) was running fine then kept having a hard time staying running. Finally when I was trying to climb out of the pond it died. Glad the truck could make it to the water to pull it out as the battery died so no winch.  I checked the fuel filter and it was not clogged. Pulled the hose and there was fuel but not alot. I could keep the engine running with carb cleaner. I have fresh non ethanol fuel in the tank so i know it not water in the fuel.
Any thoughts about what is causing the fuel problem?
