Does the Briggs 16hp have the restrictors???
Briggs Vanguard 14/16HP & 18/20HP Engine Upgrades and Identification
I have a 14 vanguard and can not get that to pull out with a plyers. Maybe I don't even have that restrictor
I now have bures everywhere from trying to get restrictors out that maybe the previous owner already did...Last edited by mikeiscool; 06-22-2013, 06:06 AM.
Just thought I would show the difference between heads, cheap way to add compression/hp to the 16, 18 and 20's. the left is the 12/14hp the middle is the 16 and right is the 18/20. you can see the difference in the chambers which will add compression, all fit each other and use the same valves, port size N valvetrain. the steel heads gaskets help also. these heads can also be installed on the 23hp but you need to switch to the 20hp intake and change the exhaust flanges and add the hi torque starter. carb jetting and or replacement will need to be made and is better suited for the guys that don't run the governor.
Thanks plumcrazy.
just a few notes that i use if i don't have any numbers to work with, should cover 99% of what ya need.
this link will let ya plug in your model # and the whole parts break down is all there.
Lawn Mower Parts, Small Engine Parts & Much More! | PartsTree.com - Briggs, MTD, Toro, Cub Cadet, Husqvarna, Troy-bilt...
just click on the briggs logo
14HP 480cc 2.70 bore 2.60 stroke
294447-0445-01
Heads
#1 / 809200
#2 / 809201
Head gaskets
806085s graphoil
807986 Steel
gasket set
808704
16HP 479cc 2.68 bore 2.60 stroke
305447-3075-g1
heads
#1 / 809200 (some times)
#2 / 845716
head gaskets
806085s graphoil
807986 Steel
gasket set
808704
18HP/20HP 570cc 2.97 bore 2.76 stroke
356447-0213-b1 except the two barrel intake/carb
heads
#1 / 809185
#2 / 809186
head gaskets
690888 graphoil
805653S steel
gasket set
841188
23HP 627cc 2.97 bore 2.76 stroke
386447-0079-g1
heads
#1 / 845713
#2 / 845714
head gaskets
842622
gasket set
842658
Please always double check the #'s as this is just my guide
