Thanks ,I'll cut that restrictor out.
Briggs Vanguard 14/16HP & 18/20HP Engine Upgrades and Identification
Thanks again. As luck would have it I scored a set of small chamber heads off the bay for $50 shipped this morning. In case anyone is interested the heads have the code 1-A and 2-A in the spring seat area, the engine these heads came from is: Model 290777, Type 0107-01, Code 90021513.
Also I confirmed that 1-B, and 2-B are small chamber heads. From 290777 0107-01 89021811
1-C, 2-C, unknown.
1-D, and 2-D are larger chamber headsLast edited by ryanvv355; 03-13-2017, 09:23 PM.
Hello Guys,
I am a Newbie so please go easy on me LOL.
I am here in OZ and have just got into Mower racing and in the process of freshening up a 35 Briggs.
You guys have some awesome and helpful info here that will help me heaps thank you.
With your above post Nubs I have got a silly question you have stated the bore and stroke of the 18/20HP (570cc) are 2.97/ 2.76 and the 23HP (627cc) has the same bore/stroke, do you know where briggs gets the extra cc's.
Is it in the heads and if so do they run high compression pistons to allow for the larger squish area in the heads.
Just curious if the 23HP heads would work on a 18HP and whether I would gain any power increases.
Thanks Guys.
Ok, I’m working on my exhaust on the 16hp Vanguard, and am freeing up a lot of flow. My carb is surging, seafoam/high octane didn’t help. Since I’m opening up the exhaust, should I switch to an 18hp carb? Does it bolt right on? Also, how are people people putting cone filters on?
Also, this may sound dumb, but are the carbs for the vertical and horizontal shaft the same?
