I have to get the tack hooked up to check rpm.s set clutches,then ill try comet 102 dont want to fly, want to pull stumps witch means new solid axles .....anybody have any they dont use need 6 bushing type.....thanks
rotax 503 in a bigmax
Originally posted by whitefisher View Postwell how do u like your 503 in your max..? how is your driven set up i have yellow spring set at 120 deg. why did u change your clutch..bad.? i have 102c i mite put on to try..! on elec.did u use regulator or recifire ...?
Ok i picked a 102c hd ,,black spring ...f arm trail .55 g. spring ten. 50lb -198lb.. new secondy stock steel ,yellow spring.....still looking for right tack... to set these up !!... time to do soild axels.......ouch!!!Last edited by whitefisher; 05-24-2013, 02:10 AM.
OK got a little time in on the bigmax...heres were I'm at stock hand throttle does not have enough travel for 36 mm mikuni Ive only been getting 2/3 throttle dont want to use plastic one,, any ideas on a all metal longer travel throttle..??? thanks;;;;;;;;;Last edited by whitefisher; 05-24-2013, 02:53 AM.
Originally posted by whitefisher View PostOK got a little time in on the bigmax...heres were I'm at stock hand throttle does not have enough travel for 36 mm mikuni Ive only been getting 2/3 throttle dont want to use plastic one,, any ideas on a all metal longer travel throttle..??? thanks;;;;;;;;;
Are there extra holes to drill out in the hand throttle? That should help w/ the throw.
Originally posted by whitefisher View PostOk i picked a 102c hd ,,black spring ...f arm trail .55 g. spring ten. 50lb -198lb.. new secondy stock steel ,yellow spring.....still looking for right tack... to set these up !!... time to do soild axels.......ouch!!!
