Kohler diesel
  • Kohler diesel
    Just noticed that kohler has there new diesel engines out. They are liquid cooled or air cooled. Air cooled 6.7 to 34.9 hp. Liquid cooled 16.8 to 64.4 hp.
    that would be nice . if dang desel fuel was not so high.
      are they expensive. Can you link me to that site?
      thanks
      Henry:
      I don't know where I'm going, but, I'm on my way...........
        You can go to www kohlerengines.com
          In the Northern Tool & Equipment catalog , there is a Briggs & Stratton , Vanguard , Liquid cooled , diesel , that list for $4,699 and weighs 280 pounds !
            A mechanic friend of mine has rigged up a series of filters mounted to a sheet of plywood. He gets cooking oil from local restaurants & has developed a 50/50 cooking oil to diesel fuel mix. I know it works because he runs his big Ford 4x4 truck with it! That makes his at pump price about $2.00/gal. or less!!
              RDR
              Fuel so high?
              I bet you could go an easy 9 hours on a diesel with a five gallon tank. Probably longer. My 32 HP tractor runs forever on 6 gallons. Fuel price and consumption in a 6x6 is very low when compared to most cars,trucks, airplanes, and our helios burn 100 gallons an hour wether there on the ground or slinging a buckett of water.
              My question and scare would be the asking price for the engine. It would be great to have a diesel in a MaxIV. Can you say torque baby.
              Rut
              2007 Max IV Hot Rodded Vanguard 18HP?
              Hi-Speed Clutch, Vampire ASX, 35MPH
                Check this out. Run it on Straight Veg Oil....USED.
                Hello KFC
                Greasecar Vegetable Fuel Systems
                  Furnace oil works too
                  You can use Furnace oil and you do not need to mix it with diesel but the filters need to be changed often
                    furnace oil around me in maine is 3.75 per gallon. Not much less than deisel. The vegie oil works from what I hear unless there are 2 or 3 others in your area that use it, then it becomes a competition to see who gets the used oil. Not sure if it would save in the long run for a vehicle. Just my thoughts
                      Those are Lombardini diesel engines. Kohler bought the Italian company about 6 months ago. They are not cheap.
                        there is a lot of work to do the veggie, new or used, oil right.....
                        it needs to be hot before it goes to the engine, filtered, and, you start and stop on regular diesel, otherwise, when everything cools, it thickens and or soldifies in the I.P.
                        There is a lot of good info out there on this issue. It's workable, just takes a fair amount of effort and attention to detail.
                        Diesel gets better economy, apples to apples, though.
                        no ignition system, "alternate" fuel capability, lower/less toxic emmisions, etc.
                        All my vehicles, that I can manage, are diesel.
                        I'd sure like my AATV to be......But, the price of a small diesel engine is as much as the AATV.....dang.......
                        Henry:
                          bio desel is the way to go. 100 times more lubteristy than desel . i love it i run it in my cummins . robbie
                            As mentioned, diesel has 2 bid advantages - fuel economy and NO ELECTRICAL SYSTEM to get wet. Big upsides for ATTV's. Slower off the start in most cases, although better torque for pulling and heading up hills. Plus then there is the safety factor. I have an old Landrover and a buddy of ours was idling his diesel rover on fall night to warm it up. We were chatting about 50' away when someone says "Hey Bob, your trucks on fire". Sure enough there were flames coming out from under the hood. We rushed over with the ashtray sand (Bob didn't have a fire extinguisher in his truck) and doused the flames. The fuel return line had gotten melted by some Lucas wiring and the fuel caught fire on a short. The 2 things I will always remember about that night is that Bob's truck didn't just explode (low flash point of diesel), and that the truck kept running through all of this. It's a great campfire story we tell at rover events every year now.
                              Do you make yours ? What kind of truck, a Dodge? Thanks Cougar
