Do the Auto-Meter Jr. Dragster tachs work on the briggs vtwin? I hook it up and reads twice the RPM. Worked on single cylinder engines.
Briggs vtwin Tach
How is it triggered? Is it a 2 stroke or 4 stroke model or setting? The Briggs will spark on every flywheel revolution, compression and exhaust strokes, so it needs to be set up for a 2 stroke motor and not for the typical 4 stroke which only sparks on the compression stroke...... There are other tachs out there that are a bit easier to read than the digital ones, and the digital ones often get confused with sensitivity too. Try more or less wraps around the plug wire (providing that's your trigger), as little as one wrap, to as much as 6. That may or may not help???
Sorry Mike, I thought you were trying to hook up a tach like one of these Briggs Sratton 19389 Digital Tach Hour Meter Tiny Tach | eBay
Look for a tach that will trigger off a plug wire. If you want a good full sized tach, this is what I have on the blue MaxII. Amazon.com: Equus 8068 Tachometer - White Dial: Automotive
It comes with the clamp on inductive pick-up for around the plug wire and can be set for the spark on every revolution.
