30 hp vanguard. What clutch?
  • 30 hp vanguard. What clutch?
    I am building a tracked vehicle for ice fishing. I have a t20 transmission and plan on putting a 30 hp vanguard big block on it. The t20 cam out of a max II and has original clutch on it. The motor in it is a Polaris 2 stroke. Does not look like a 780 clutch. What clutch should I put on the motor?
    Do you mean the Briggs 31HP Vanguard? If that's the case, you'll need a Comet (1190 I believe is the number) clutch for a 1-1/8 keyed shaft. You could also probably get by with a Comet 94C Duster clutch for a 1-1/8" shaft. The smaller clutch in the background of this pic is the 780 and this model will only work for engines with a 1" keyed shaft).
    209739A - Model 94C 1 1/8 Bore | Snowmobile Parts | MFG Supply
      What rpm should it engage at?
        I don't know off the top of my head, but the clutch in the link I provided is all set up for 4 stroke engines. You will need to match the driven clutch spring with the drive clutch. You will also need a red or green 4 stroke driven clutch spring to put in to the one that's on your transmission if the Max originally had a 2 stroke engine in it. You can get them here and they're not expensive:
        Amphibious Six-Wheel Drive All-Terrain Vehicles: MaxATVs - Call 1-800-255-2511
          The RPM engagement for 4 strokes will be 1700-1800. Depending on your engine and machine requirements you may be able to fine tune that a little lower. Tuning the clutches is a very time consuming trial and error process. It is best to order it/them as close as possible to what you need, and hope it's good enough.
          Give Roy a call Quality Drive Systems and he will set you up.
            Thanks for all your time! Very nice group of people on this sight! That info should help a lot! Thanks again!!!
