Hello Everyone,
I've got a 1997 Bigfoot that seems to have a fuel starvation problem only going up forwards on steep inclines. It did it with my single barrel stock setup and it still does it with my new 2-barrel setup, otherwise it runs perfectly.
I took off the pulse pump and cleaned it, new filter and lines, cleared tank intake etc, no change. I believe the pump can't push enough fuel when needed.
I'm thinking of a low psi electric pump, but don't want to burn down my Argo. Has any one figured out how to wire in an electric pump that will shut off if the engine stalls?
(Not just if the ignition key is turned off) Larger engines use an oil pressure relay, but this would be tough to adapt to work on a small Briggs 18HP.
Thanks for any and all suggestions.
(Not just if the ignition key is turned off) Larger engines use an oil pressure relay, but this would be tough to adapt to work on a small Briggs 18HP.Thanks for any and all suggestions.
