new to 6x6 world just bought a well used 2006 8x8 argo frontier engine bogs when turning I think its done thought about 22 predator don't know if shaft size is compatible with cluch
Predator 22 hp
We run mostly these predator engines. You will have to build a custom exhaust for them. Pretty easy you can buy the flanges and go kart pipe separate or there is a kit.
Exhaust, Flange, Header, GX270 to GX390
Exhaust, Flange, Header w/stub, GX270 to GX390
Honda GX670 GX690 V-Twin Header Kit
Honda GX670 Predator 670cc V-Twin header collector kit
My next build will be a 2 into 1 and see how it sounds.sigpic
i just recieved a 670 for an anniversary gift from my wife. needless to say, it will be going into her MaxIV. Need some help with wiring,, what all do i have to do or get rid of to make it compatible to my MaxIV. It is currently wired to receice a Kohler Command that I put in last year but failed shorltly after but had a Briggs in it originally. Also, what belt is used for this conversion or can the original Briggs belt work? Thanks guys!!HUSTLEMANIAC and a HONORARY MEMBER of the
BIGFOOT ALUMNI
Get ahold of Tommy or the Michiganers, they've both just done them.Originally posted by fmints View Posti just recieved a 670 for an anniversary gift from my wife. needless to say, it will be going into her MaxIV. Need some help with wiring,, what all do i have to do or get rid of to make it compatible to my MaxIV. It is currently wired to receice a Kohler Command that I put in last year but failed shorltly after but had a Briggs in it originally. Also, what belt is used for this conversion or can the original Briggs belt work? Thanks guys!!sigpic
