Hey all, picked up a 98 max IV for a buddy of mine a couple weekends back, and am having a hard time getting it to rev smoothly. Video gives explanation, but incase it doesn't work...here's the issue.
When idling and NO choke, it almost acts like it's flooding out. It loads up, then revs up. At about half choke, no issues at all, idles fine, revs fine etc. whether it's warmed up or not, half choke seems to be the sweet spot. With the air filter off, and NO choke I can see gas spitting out of the top of the carb when it sputters.
I've replaced the plugs, checked the valves, and took apart the carb spraying every jet, cleaned out fuel bowl etc. saw nothing really that would prevent it from running right.
Could anyone shed some light on this?
   So off came the top of the carb to check the bowl, to see if there was any gunk from the fuel....none, BUT, noticed the float was rubbing against the inside of the carb. So "adjusted a bit" runs better but not entirely there yet.  Convinced it's the float. So tomorrow, I'll go grab one....fingers crossed!
