heat?
  • heat?
    Hi all,
    It's gotten really hot here, northern CA, and, I'm wondering if anyone adds extra cooling to their engines, and, if so, how?
    My Hustler seems pretty hot when running in this weather.......I was thinking an oil cooler if I knew where to find a pressurized port.....it's got a 16 h.p. BS engine.
    Thanks,
    Henry
    Henry:
    I don't know where I'm going, but, I'm on my way...........
    I'm trying to get my friend to make me a 90* filter adapter with ports for a cooler!
    I'm tinkering with adding an electric fan to thestandard cooling system!
    For any air cooled engine heat is it's worst enemy.
    Jeff
    02 Argo Bigfoot
      I was thinking of a closeable deck, with a reversable fan, so, it could be open and the fan would help draw hot air away from the engine, pulling it in under the seats and floor, but, in cold conditions, closing the rear deck and reversing the fan would blow warm air under the seats, etc.........
      Henry
      Henry:
        I don't see a filter on my engine. am I blind?........yikes.........
        Henry
        Henry:
          on my max2 with the 25hp kohler i replaced the engine cover in the top body with an 8 inch aftermarket automotive coling fan and do just what you described reverse it in the winter for heat!!!! also the factory uses a fresh air duct to grab fresh cool outside air and direct through the fan (flywheel) and on the exaust side there is shielding around the exaust to divert the hot air out vents on the other side shouldent be to hard to make something simalar for a hustler if i get time in the next fue days ill snap a fue photos of my setup ive gotta pop the top and lube stuff and change the choke cable anyway i know you have a compleately different setup but maby it will inspire an idea or 2 ya never know!
          they dont call me mad because im angry!!!!! im just a little crazy thats all!!!!
            thanks mad max....that'd be great.
            HEnry
            Henry:
              When I got my husler, the hot air box was missing. There was nothing to make the heat exit the unit!! Yes they do have vents, but it is not enuff. I took 1/4" rubber sheet, ' old convair belt to be honist' and fashioned a baffle to force hot air from the motor, past the hot exhast, and out the back vent. Hot air go's out----cool air must go in, problem solved!!!
              Anther thought I have not yet done, Take a 12v blow from a old cars heater, mount it so it draws in fresh air through one of the side vents, One ****ch and you should be able to move alot of air!!!!
                good idea, thanks........
                Henry:
                  Not sure what kind of room you guy's have to work with, but a jeep cherokee electric fan is about 12"x12", and easily mountable. You would need a 40amp relay to run it, a switch would not handle the current.
                  eBay Motors: JEEP CHEROKEE/COMANCHE RADIATOR COOLING FAN NEW 87-01 (item 330236166304 end time May-20-08 15:56:47 PDT)
                  Jeff
                  02 Argo Bigfoot
                    I found a little somthing! Any one have the napa oil filter # for the 18HP B&S
                    I can cross it up & get the measurments tosee if any of thes will fit.
                    Sandwich Adapters
                    Jeff
                    02 Argo Bigfoot
                      You don't want to use the Briggs factory oil cooler adapter?
                        Roger:
                        can you tell me more?
                        thanks,
                        Henry
                        Henry:
                          I wasnt able to find any info about that online! Got a link?
                          Jeff
                          02 Argo Bigfoot
                            Not right off.. but it's a factory option or add on. It uses the same oil filter adapter except it's drilled and tapped for two lines. I think from the factory it is mounted up against the engine cowling and gets a breeze off the flywheel fan.
                            Whipper has photos somewhere, richard clark at route6x6 sells them. Whipper's pics shows a bigger cooler and fan.
                              I shal contact Richard
                              Jeff
                              02 Argo Bigfoot
