Does anybody know where I can get crank bearings for a 292 yamaha motor
I went to the local bearing supply house and they tell me its a OEM part that hasn't been imported into the states [ever] no cross ref is available.They even called japan the koyo supplier and nothing is available.I went to the local bike /snowmobile shops and got the same info. All the dim. are stock size [od.width] except the ID is 32mm and stock available industry standard is 30mm ID The only other option is to have the crank turned down to 30mm to fit the stock bearing size. Any help
/ideas would be greatMaybe some day I will get the scrambler running
Thanks tlp
