How long usually does the flywheel that creates electricity to charge the battery last for I don't think it has ever been replaced in my 1992 magnum so would that be the reason why my battery is not charging
Magnum flywheel
I would suggest checking or replacing the rectifier/regulator. I had an Argo I/C with the Kohler 17 hp engine that stopped charging. At first I misdiagnosed it - I bought a stator, thinking that it was the culprit. But it was the rectifier/regulator. Once I replaced it, the engine charged just fine.
I'm assuming of course that you have a Kohler engine.
you can test the stator out put with a volt meter if you have one. disconnect the two outside leads on the rectifier and connect volt meter to 200 volts a/c and crank engine run up rpms and it should read between 25 and 30 volts a/c. if you don't get that voltage it is not working. if you get 25/30 volts a/c than test rectifier it will be the center lead and it should read 13/15 volts dc.
1980's Kohler Magnum 18hp Motor ~ Stator
Would the connections work? Someone suggest for me that is not to expensive and still works that would for a m18 kohler
Before purchasing the stator test as described above. AC voltage should be above 28 volts. Also test the resistance of the coil on the same two wires. 15 amp system is supposed to read .1-.2 ohms. 25 amp system is supposed to be .064-.096 ohms. The eBay one you posted should fit. It appears to be a 25 amp coil. If your resistance shows open or 0 ohm the coil is bad. Sorry to say they are usually destroyed by loose magnets from the flywheel. Test it properly before spending any money on parts. You also must have battery voltage to center terminal on regulator with engine off. A bad fuse will kill the charging system.Last edited by msafi65; 01-19-2016, 01:09 AM.
Best thing to do is go to Argo adventure website. Look up magnum manuals and download the m18-m20 engine manual. The electrical section is very detailed with drawings as to what leads to test. The previous posts here cover most of it but the diagrams will help a bunch. I've seen people spend hundreds of dollars on unnecessary parts by jumping in without testing. Good luck.
