I read a old post about having to have the choke on even after engine is warm to restart.My kawasaki 27 hp has been like that since I purchased it new in 2004.After years of use it started running on only one cylinder spark was fine to both plugs. Pulled carburetor and cleaned twice
Still same issue. The third time I was in the sun and noticed small pinholes on the side of the throat of the carb. I believe two on each side maybe four I don't remember. I Tried a pin and needle nose pliers but the holes were to small.
I ended up using a straight welding tip cleaner super small and needle nose pliers to clean them out they were all plugged. Since then no choke needed after initial start its been two years.
