Update did compression test last night and both cylinders came in at just over 100 psi, which is according to service man is OK. Jim i did have a issue this winter with the fuel pump and had to replace the valves in it. Guess going to have to do oil change, which means pulling the motor i guess unless someone has better way of doing it on this older machine. Pictures showing cable that is interfering with the breather tube
Oil blow back on 84 IC with kol twin series II
I had the same engine in the same machine years ago. this was my solution. takes a long time but gets the job done. http://www.6x6world.com/forums/gener...extractor.htmlA well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
Thanks for the tip. I will have to see if i can find the parts to make one, had not thought of using dipstick tube, just knew i could not use oil fill tube.Even draining into the tub would be a chore as i would have to strip half the stuff off the engine just to get at the drain plug.
Pull the engine? Ouch! I would do this if it were the only way but only ONCE. It would go back in with a hose barb in the drain hole,a piece of (correct type) hose and one of those cute quik-drain vales (or any other type of valve) on the end. This gets the necessary components within reach. Then can be routed like Jeff-t-boss says in his post replying on racerone3's thread of the neat extraction system he made. As far as the cable in the road situation,perhaps the hole ca be relocated in the air cleaner housing base. Or,again,do as racerone3 says and just do the "external" containment method. I'm sure this works just fine.Originally posted by Aahicnow View PostGuess going to have to do oil change, which means pulling the motor i guess unless someone has better way of doing it on this older machine. Pictures showing cable that is interfering with the breather tubesigpic
Update 2
Took racerone advice and made oil extractor , oil was very thin so i refilled with 30 weight to full mark and ran for a bit will check tomorrow to see if level comes up.
I guess carb or fuel pump next
Pic is of oil extractor, fanta bottle and a piece of air line tubing.Attached Files
update next day
Took machine out for quick run to day and had a bit of blow back on the engine cover above the fill tube. That is until i tried to climb over the snow bank that produce oil everywhere under the hood oil seems to be up again so i am assuming fuel in oil again.
Just read something in service manual, can someone clarify for me it says you should have a negative pressure on the dipstick tube( where it says to do mano test)which i do not i have positive pressure it is blowing out on the dipstick and the oil fill, This means that something has to be creating a vacuum. Is this what the rubber tube is suppose to do that runs to the breather? If this is the case any holes in this tube will decrease the amount of vacuum. If this tube is to produce vacuum,what stops it from sucking oil up into the air breather? Does the placement in the airbreather make a difference (ie closer/ further from the filter) This goes back to my problem with the cable obstructing here the hose is suppose to install see picAttached Files
A 4 stroke v twin engine should have very little crank case pressure or vacuum. As one piston goes down, the other is going up, so there is about the same air volume at all times. If an engine had NO LEAKS, and the crank case breather was properly routed to the air filter there would be negative pressure at the dipstick. As an engine wears you start getting pressure leaking by the rings, and valve seals (in the case of a flathead engine like yours) which cause a bit of positive pressure. This is where a leakdown test is helpful. The breather assembly has baffles to keep oil out, and is located high in the block well above the oil line. all that should push out is the airborne oil vapor. Typically with the breather into the air filter, this vapor is burned off with the air/ fuel mixture. If you are getting fuel contamination, your oil gets thinner, and therefore vaporizes much easier.A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
This is a longshot and perhaps a dumb question....but here goes. Does this problematic engine have any type of splash guard inside the crank case to keep oil, splashed about by the crank, from getting into the breather tube? If so, if the splash guard has broken or come loose could that be his problem? It sounds like his problem gets worse as he gets on inclines (see post 21). It sounds like his problem is worse than splashing, but just thought I would float this idea.
Ok Racerone I am going to try hooking the breather tube back to where it is suppose to go,and put a new air filter in and see if this get rid if the positive pressure at the dip stick. I will just have to watch out for a stuck throttle. If rerouting if fixes crankcase pressure issue, i will then see about rigging something to prevent the throttle stick issue.
If I am rite there should be a filter in the vent plate. Like a webbing of sorts. I have seen them get oiled up pretty bad and if you take it out and wash it out then let it dry it should be good after install.
If you pull your dip stick out and it blows air out of the tube when you rev it then you may have bigger problems ??
Got this straight out of service manual
If there is no pressure or positive pressure(at the dipstick tube (which i do have)) do the following,
a: crankcase breather clogged or inoperative:, Disassemble, clean reassemble, recheck pressure (in proccess I did try blowing air into the tube and it did exit out the filler tubeand dipstick so thinking not blocked, will reinstall in correct postion tonight )
B: seals or gasket leaking: (hope not)check for proper sealing of crankcase
C: Blowby or leaky valves: Check compression (Done 101 psi in each cylinder)
d: Exhaust restriction : Check Muffler (dont think i have problem here)
When cleaning the breather check all parts in the manual, the last Aegis I did (because it blew the cam seal out) has the fibre and a metal tongue which according to someone else can rust shut, break or move sideways so check that that is where it belongs if so equipped.sigpic
