geo metro engine help
  • geo metro engine help
    hello all out there'
    i need help and advise to install a geo metro 1 liter engine on my attex super chieft. i have the engine, the throttle body carburator, and all except the harness and the ecu. anyway i can bypass this ecu? my plan is to install the vw carburator in place of the throottle body. what your advise?
    I believe you will need older carb model ignition system also. Contact spookum on this forum. I did the machine work for clutch mount on his Argo with the geo motor. He pulled the entire engine harness and ECU and used the injection. It's a very powerful little engine that makes some serious rpm. The geo-Suzuki forums may have info on getting spark with a carb motor.
      Keep the fuel injection and electronic spark control.
        That is a lot of motor to go in an Attex. HP wise the S.C. can handle no doubt, the torque on the other hand is a different matter. I think that the frame will need to be reinforced, and of course high torque motors will find any weak link in your drivetrain such as old bearings, worn chains and axles, etc. I do think it would be a heck of a machine when you get done and I've never even thought of the Suzuki motor for an Attex. Several folks seems to have very great set ups in Argos, Tracksters, etc. using these motors. They are extremely reliable, long lived engines, and of course being water cooled, you can add a heater if needed.
          geo metro engine
          i have the geo metro engine without ecu. do you have to install the ecu to make it run or can you bypass it. the reply with any advise to my email thienlu1@yahoo.com. thanks in advance
          Last edited by Mike; 03-01-2017, 07:08 PM. Reason: moved post from another engine thread out to your own thread
            Contact CarGuy on the site , he has a Super Swamp fox with the ecu and injection set up on his machine and it works great. I'm also putting it in my Max IV mid-mounted using the injection, its much more reliable and responsive than a carb set up . Good luck
              I was just going to suggest that, I was down at his shop last fall buying tires from him and had a chance to check out his Super Swamp Fox. Very well thought out and clean install. I would also keep it EFI, more pros than cons.
                Hi guys! I still do lurk.
                You need an engine management system- absent activating the injectors it is responsible for telling the coil when to make spark, and this also involves spark and therefor timing advance. I believe you could jerry rig something, but there is no way it will ever run at a satisfactory level. If you want to, you could adapt a "micro squirt" box and shoe horn in the wiring, but it may or may not work. I learned ALOT from the guys at Geo Metro Forum.
                What you need for a G-10 motor swap:
                Running engine (try to find a car that runs with a blown trans. Once you start asking around, seems like there is one or two some place.)
                Wiring harness
                ECM
                transmission from the car- so you can cut the bell housing to mount the starter.
                Inline Fuel pump- if it s throttle body injection it will need 40 PSI- i forget the napa part number
                Relay for starter (napa)
                relay for fuel pump (napa)
                Return fuel line if it is fuel injected
                radiator, and radiator and radiator fan
                clutch
                clutch adaptor to the motor.
                4 "pucks" snow mobile style for motor mounts
                fabrication skills to mount the motor
                The reason IMHO to plant a G-10 in an AATV is because it is a cost effective means to get a reliable fuel injected power plant that is four stroke. If you want something that is turn key ready to rock, look at any 340 or 440 fan cooled snow mobile engine (hopefully with electric start)- WITH the ecm and coils and clutch (you should be able to source a complete 1990-2000 sled for $500 and put a top end in it for 300). Just jet it for your temperature and altitude and have a blast... this elimantes the electric fuel pump and radiator and a TON of electric nonsense.
                ATV = Alaska Terain Vehicle
                  Pictures buddy!
                    There are pictures of carguy's swampfox in his gallery.
                      Wiring harness
                      ECM
                      clutch
                      Fantastic post!!!
                      I'm going to mount a standard assembled Megasquirt II 3.0 board under the dash of my Max sometime after I do the re-wire to start watching RPM, mass air flow, etc signals so when I eventually put an injector to it I'll have good data. Back on point, the Microsquirt box is effectively a better sealed smaller version of the Megasquirt II. You have to have some wiring aptitude, but I've stuck these things in a '67 Thunderbird, '69 Firebird and a '77 Skylark, so I'm very comfortable wiring and plumbing these type of things in, but it's a steep learning curve for the first one. There is something nice about going with the minimalist approach though too! All depends on your goals and patience.
                        I can't wait to see it! Those guys on that geo metro forum, from what I understand, love the mega and micro squirt boxes- they get nutso mpg out of the geo!
