Hello everyone,
I'd recently introduced myself on the forum and it's been a pleasure to talk with everyone and I look forward to meeting some of you in person soon. But meanwhile, i'm still trying to get this 2003 Argo Response 8x8 (Vanguard OHV twin 18hp)to run properly for me. I'm open to any advice someone may can offer.
I picked it up used from the previous owner who apparently didn't operate it very often and the gas had turned stale. The local Argo dealer had put on a new fuel pump, new lines (I think), fuel filter, and cleaned the tank for him just last week. The machine still smells of very old gas. When I tested the machine and for the 1st 30-45 minutes of running it at home, it ran fine. After this it started failing to idle and will cut off when ever you stop unless you keep it idled up. Of course, if you want to change gears it's kind of hard to keep it idled up or if you're crossing difficult terrain and need it to idle, so it's a real problem for me.
Here's what I've done so far.......2 new spark plugs (RC14YC .030 gap), New starter solenoid (still has starting issues too), ran some more carb cleaner through the filter and carb, Moved the filter further away from the side of the engine in case it was too hot causing vapor lock, and finally added a product called "SeaFoam" to the tank of fuel to dry up any moisture and help more with cleaning the tank. I should add that even now the first 10 minutes from a cold start it runs fine, especially if the choke is still being used, after that.......stall, stall, stall
I'll take any advice you guys can give! Thanks in advance!
Andy
Andy
