Hey fella's, i have a primary and a secondary clutch setup from a 2004 Argo Avenger but they are for1-1/8 shaft so just wondering if anyone has made a spacer to fit a 1-1/8 on a 1 inch shaft?
) it can take a slight angle and start getting gouged by the corners of the shaft and clutch keyway, getting to the point it can shear. I think I will TIG it into the spacer so the key cannot try to cock to one side, since I can't really weld the spacer to the clutch or shaft well enough.
almost forgot, make sure that your new key is tight fitting and as long as possible
