All you folks that have a Briggs 18hp or similar motor, what RPM are you able to idle at without lurching the engine on the governor?
I just installed a Sendec tach on mine and I'm having problems getting a good reading. What ga. wire do you use and where do you mount it? The Sendec says you can use anything 22 ga. and above. I've got 16 ga and I'm not getting a good, consistent signal with 8 feet of wire. How do you get around the length limitations with the tach? I see that the Tiny Tach max length is only 6 feet.
Thanks
Thanks
