I need to get a new coil what kind do i get?????
jlo 297 questions
jlo 297 questions
Well I pulled the carb off to see why its spitting fuel out the front of it and took it all apart. Inside where the needle is there is a pin hole that doesn't look stock all little burrs on it and stuff so i think thats the problem new carb and plug and she should fire up. I look in and the piston moves fine no other signs of somethin going on. Should I check anything else??
Jlo
disconnect the fuel line. turn it over with a clean spark plug. then try it with a little gas /oil mix, not much,should fire right upOriginally posted by ArgoH2 View PostWell I pulled the carb off to see why its spitting fuel out the front of it and took it all apart. Inside where the needle is there is a pin hole that doesn't look stock all little burrs on it and stuff so i think thats the problem new carb and plug and she should fire up. I look in and the piston moves fine no other signs of somethin going on. Should I check anything else??
wiring.....
disconnect all wiring, then try it, it will still start.Originally posted by ArgoH2 View PostI tried that earlier today still nothing lol this thing is killing me. The wiring doesn't look right either I have to figure that out he had wires cut laying all over.
UNLESS the 2 smaller wires are backwards
jlo
No power to coil...... if it is the origional coil. you'll fry somethng, then no sparkOriginally posted by ArgoH2 View Postok so pos from battery to coil put the carb back on and new plug. wi;ll it still start if its spitting fuel out the front of the carb?
you'ld burn out the points
spitting fuel out is too much fuelLast edited by Amphiman1; 09-12-2009, 10:08 PM.
