ok hey thanks for all the help I am all new to this stuff. How should I hook up the coil? and does the 3 wires coming out of the back of the motor do anything?
jlo 297 questions
I dont know that engine at all, but in any generic coil, the power wire goes to coil, the negitive side of coil goes to points. The points act as the switch to tell the coil when to spark the plug. If I get a chance to marrow I will look at my parts st300d machine and see if I can help at all. Thats the only machine I have ever bought that had an oem motor. And 1 of 2, I have ever bought that actually had a motor.But I havent really did anything to it but steel the trans. Its at my brothers house in his barn and I havent looked at it that closely.
Originally posted by ArgoH2 View Postman this guy hacked this poor machine right where the 3 wires come out of the back under the exhaust there is something that looks like its missing appears to have 2 bolts to mount whatever should be there.
You should be able to check continuity and find the one that gains and looses as the motor turns to find the right wire that goes to the points. Or maybe have to pull the flywheel off. But when you find that it should run to the neg side of coil.
one should be lighting coil, it produces the power to the lights. Other is charging coil that keeps the battery up to snuff to crank when there is no spark, lol. Both are different then the ignition coil.
The 3 wire is points.
If there is another it could be for the grounding of the coils to shut engine off.
ok so i got a new plug pos from battery directly to coil neg side to one of the 3 wires sounded like it wanted to fire with the starting fluid I hooked gas back up and nothing again I pull till my arms fall off and nothing I am thinking the other 2 wires out the back are for something just not sure what. The coil gets really hot too????????????
Originally posted by ArgoH2 View Postok so i got a new plug pos from battery directly to coil neg side to one of the 3 wires sounded like it wanted to fire with the starting fluid I hooked gas back up and nothing again I pull till my arms fall off and nothing I am thinking the other 2 wires out the back are for something just not sure what. The coil gets really hot too????????????
