How many HP's does the Bandolero engine produce?  WHat makes them so superior to other engines?  WHat mods do they use?  Thanks!!!
 check out these GENERAC engines( AMERICAN MADE ENGINES)http://www.6x6world.com/forums/ebay-...orse-67-a.html
would you consider a generac MONSTER
Good morning: This engine would be rated at about 20hp & 56lb ft of torque at 1800 rpm. 1800 rpm is only slightly above the normal idle speed for this engine (1400rpm) Running it under a heavy load at 1800 rpm would not be recommended. Maximum torque is about 68lb ft at 2400 rpm (based on the SAE J1940 test method) Maximum hp is about 44 at 3600rpm (based on the SAE J1940 test method) It would be best to use belts & pulleys to run the engine at 3600rpm & your equipment at 1800rpm Let us know if you want to consider this option THIS A QUESTION A GENTLEMAN HAD BUT TELLS YOU A LITTLE MORE ABOUT THE ENGINE  TORQUE AND HORSEPOWER AT DIFFERENT RPM LEVELS  /TORQUE MONSTER WHO WILL HAVE  THE NEXT GENERAC MONSTER or i will need a mirror so i can see you all behind me
 just kidding
 HOW MUCH FOR A BANDOLERO$$$$$$$$$$$$$$$$$$$$$$$$$$$ at what horsepower vs torque i beleive you need torque more than horespower for 6 wheeler. I would love to see the torque curve for some of these engines.
 generac is now building custom engines
 just keep restoring and keep them rolling later jeff
