sounds like you have multible problems..you may have a worn out piston and rings..if when running
does it make a tinging noise ? if so it need piston and rings if not check the compression it should
be a low compression engine around 90 psi should be good..anything significatly lower is bad and it
should have a good snap to the spark and blue strong..in cold weather two stroke oil is heavy therefore
your compression should be optimum for the oil to burn off other wise what happens is it loads up and fills
crank case with fuel....thats why the sinthetic oil works better.......KEEP CHECKING AND YOU WILL FIND THE ANSWER
) Now I know that you can run much less oil with today's oils, but I still run the 20:1 and don't foul, a little smoke, but not bad at all, and you get more power too, up to a limit, usually around 20:1
