I swapped a 12.5 hp Briggs with a new 23 hp Briggs and now my primary and driven clutch do not line up. They are aproximately 3/16" offset at this point. My old motor did not have a washer behind the primary clutch and the engine boss on the crankcase was shaved so the primary clutch sat very tight to the crankcase. I need to run a washer behind the primary on the new motor otherwise the clutch hits the crankcase. Should I simply shim out the driven clutch using washers or is it possible to shave the engine boss on the crankcase?
clutch alignment on Max II
