Cylinder Honing Grit
  • Cylinder Honing Grit
    Rebuilding a G50B. What grit stones would you guys use to hone the cylinders? Cylinders look nice, just a de-glaze.
    sigpic Attex, there is no substitute
    I believe 240 is typically used. 320 is also popular but it often depends on the recommended finish for the rings you are going to use.
      hi ,
      Your engine may have a recommended finish if u could find a manual grit no and angle
      4 stokes deglaze around 320
      If u choose u could have it done by a machine shop
      modern honing machines method can use a diamond hone 600 "grit"
      A finer finish will give better sealing but the chance of glazing during the run in process is high
      Although many have honed by hand for years a machine hone will give a better result even if u elect to go with a coarser finish
      This all depends on ther condition of the bore [ does it measure up ] and the type of rings u will use
      Typical measure ment are allowable up to 2 thousands of an inch wear taper and ovality
      3 thou is borderline
      3-5 thou time to rebore
      tomo
