Rebuilding a G50B. What grit stones would you guys use to hone the cylinders? Cylinders look nice, just a de-glaze.
Cylinder Honing Grit
hi ,
Your engine may have a recommended finish if u could find a manual grit no and angle
4 stokes deglaze around 320
If u choose u could have it done by a machine shop
modern honing machines method can use a diamond hone 600 "grit"
A finer finish will give better sealing but the chance of glazing during the run in process is high
Although many have honed by hand for years a machine hone will give a better result even if u elect to go with a coarser finish
This all depends on ther condition of the bore [ does it measure up ] and the type of rings u will use
Typical measure ment are allowable up to 2 thousands of an inch wear taper and ovality
3 thou is borderline
3-5 thou time to rebore
tomo
