I have a full manual of the breakdown of every JLO/Rockwell engine out that was in early 6 wheelers so if anyone needs any repair or specs on them let me know and I will gladly provide that info!
JLO/Rockwell Engines
Do I still have your copy? If so I need to get it back to you ASAP. I'm lookin' over at the pile of AATV stuff here at work (Attex axles, inner and outer bearings, 2 dozen manuals) and it looks like your is on top...
Perhaps if there's room on the board, I could scan it in and make e-lectronic, ay?
~msigpic
395 jlo rockwell?
Do you have service manual on a 395 jlo rockwell? please call lance @ 262 930 3633 Thankyou!Originally posted by jpswift1 View PostI have a full manual of the breakdown of every JLO/Rockwell engine out that was in early 6 wheelers so if anyone needs any repair or specs on them let me know and I will gladly provide that info!
This should help:Originally posted by hoeguy View PostDo you have service manual on a 395 jlo rockwell? Thankyou!
All you have to do is click this link and it will download for you. It's a pretty large file so it may take some time to load for you.Originally posted by gadgits4u View Postif this manual is a pdf file or ms files may i please receive a copy for my JLO L295L.
Thank-you
I need some info on the jlo295. I am pretty sure it is a 295. It is a single cylinder. I need to know if the plug for the wires is needed for case pressure to build. I am having pulse pump issues and I want to weed this out as the cause. Thanks
Is the pulse line coming from the port on the crank case and going to the pulse fuel pump clean, new, and not kinked? If not you might want to replace it because that could make it act up."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
