Originally posted by sofob0909
View Post
JLO/Rockwell Engines
There is no case pressure, only a pulse that is created by the piston going up and down this is what makes the fuel pump work. If there is no pulse or a weak pulse at the line coming off the crank case you either have a bad crank seal, low compression or maybe the drain plug on the bottom of the crankcase is loose or missing.
