Ok guys here is my problem finally after a year got my argo together turned the key and saw smoke from the front of the engine (the starter side)  anyone got a clue on where to begine.  Here is what I know the batter is fully charged and working fine,  when I turn the key nothing no click no nothing.  Everything is wired correct my thought is the wire I spliced in for the hour meter that was lose hit the block and shoted somthing out.  The fuse is also not blown
20 hp kohler command wont turn over
just asking because if you went into the engine or rebuilt the engine or what have you, and you torqued down the connecting rods too tight on the crankshaft, the engine won't rotate over, thus making your starter smoke or burn up,,,,,, just clicking or no clicking at all!!HUSTLEMANIAC and a HONORARY MEMBER of the
BIGFOOT ALUMNI
Not knowing the engine or machine history I wonder if there is a fusible link in the wiring at some point. Typical place would be from the hot side of the solenoid in the wire going to your key switch. Check the wire(s) for continuity. When they go out, sometimes it is not readily apparent to the eye because it looks like regular wire. Something opened up the circuit maybe a short causing too many amps to be drawn and the smoke you saw was coming from a fusible link wire that is there to protect the rest of the wire harness?sigpic
Max 6 Wheel Drive
