Need help IDing this carb
The carb is actually a Walbro WD, WR, and WDA series carburetors.
Here is a link to the manual.
The center fuel line is the feed and the side/edge bottom port is the return/vapor line/. there is a purge line as well on top. Last page of manual shows setup.
I'd highly recommend replaciing the Walboro with a MUCH more reliable Mikuni VM series round slide carburetor. You'll prevent so many headaches in the future."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
Why? I thought that the pulse pump style would work better in off camber situations. Do they just gum up?Originally posted by jpswift1 View PostI'd highly recommend replaciing the Walboro with a MUCH more reliable Mikuni VM series round slide carburetor. You'll prevent so many headaches in the future.
How much is a VM carb and is it bolt and go?
Where can i get a VM carb that is the right size/ how do i find the right size?
It's not so much a reliability issue as it is a performance issue, it should run a lot smoother with a mikuni on it and not near as much periodic carb adjustments as with the walbro. For some reason I could not see the pics of your carb but you may be able to bolt on a HR series mikuni carb. What engine is it on? I have a few HR series and if it will work I will send you one.
its a jlo. Single cylinder. Pm me with what you have and what you are asking.Originally posted by Joe H View PostIt's not so much a reliability issue as it is a performance issue, it should run a lot smoother with a mikuni on it and not near as much periodic carb adjustments as with the walbro. For some reason I could not see the pics of your carb but you may be able to bolt on a HR series mikuni carb. What engine is it on? I have a few HR series and if it will work I will send you one.
