I have a 1995 Max IV with the Kawasaki FD750D engine. I actually acquired it from my father-in-law after it had sat in storage for a couple years. He had it "serviced" before I picked it up...not sure what services though. It ran good for the first few months of limited use. But last time I had it out, in March, it conked out. I was only able to drive home with the choke full on. And so it has sat for the pas few months.
I wanted to try and get her back in action now that the weather is cooling off. So I drained the fuel out as best I could, removed the carb and gave it a good soaking in carb cleaner and blew out any holes with compressed air, reinstalled the carb and refueled (added in some Seafoam). Now it still will only idle if I hold the throttle about 1/2 way; it will drive but very weak unless I pull the choke about 1/3 then it drives better.
So I am guessing that I need two things...replace the gaskets and seals in the carb and possible adjust the carb. This presents two problems: where can I find a carb rebuild kit for this engine(Dr Google has not been too helpful)? And I have no idea how to adjust the air-fuel mix on this carburetor. Any pointers?
You can assume I am a novice mechanic with decent hacking skills.
