The rubber belted Adair tracks are 3 inches wide and 1/2 thick. The rubber belt fits through a slot in each grouser and is pinched together by a 3/8 stainless steel screw. I was told that in 5,000 hours of use these belts will only stretch about 1%. The belts are held together with two stainless steel hinges. The belts are adjustable when you by them
Adair ' rubber belted ' track swim test
Ill have to wait and see how the rubber belted tracks work on Kghills Hustler. I may need to buy a set if they are that much better.HUSTLER 980 NOS BUILD
HUSTLER 980 TRAIL MACHINE
HUSTLER 950 PARTS MACHINE [
Remember, in general, the 8x8s will swim faster than the 6x6s with Adair tracks. Tim previously has not advertised the tracks as swimming tracks even though they do swim. Typically most other tracks will not propel the vehicle at all. Your Hustler has the same 25x12x9 tires in the tracks as my Max. THey look to swim about the same. THe tracks for my Hustler will be built around 28x12x12 tires turned down to a 26.5" diameter at 7PSI. The rear tires will about touch and the grousers will be at least 1.5 inches tall. All the Adair seem to be good in the mud. Some are just made differently than others as time progresses.Originally posted by highrollinmopars View PostIll have to wait and see how the rubber belted tracks work on Kghills Hustler. I may need to buy a set if they are that much better.
Keith.sigpic
Just caught this thread and wanted to correct and clarify a few comments....Originally posted by mudbug3 View PostThe rubber belted Adair tracks are 3 inches wide and 1/2 thick. The rubber belt fits through a slot in each grouser and is pinched together by a 3/8 stainless steel screw. I was told that in 5,000 hours of use these belts will only stretch about 1%. The belts are held together with two stainless steel hinges. The belts are adjustable when you by them
Thank you all for the kind comments, but belt stretch of the 1/2" thick, 3" wide 4 ply belting is claimed by the mfg rep to have an expected stretch of less than 1% - 2% over a 5 year period of use...they don't claim that on any particular application of use or hours of use, but they build a lot of specialized belting for some really large equipment builders and claim that this is overkill for the Adair track application...we will see...that amount of streatch on a 234" long track could still be 2-5 inches and the adjust can be easily made by simply repositioning the last grouser on the belting and cut the hinge off the end of the belt and reposition it...this would shorten the track about an inch if and when necessary.
Second thing I noticed is that this new design does currently use a custom Adair hinge splice that is made from stainless steel..the bolts that hold it on and the pin that hold it together are standard zink plated steel...also the lag screws that clamp the grouser to the belting are high quality 5/16" x 4" GRK outdoor fasteners....these screws and the few hinge bolts could easily be provided in stainless for minimal cost but most consumers would not benifit from the added cost so the standard Adair belted track does not come with all stainless fasteners..
I don't mean to get in the middle of these conversations and do appreciate all of the kind comments, but want to try and make sure that the info is as correct as possible.
Thanks everyone
Tim
