Originally posted by Sparx
View Post
Sparx, I think the rubber tracks by far cause the most wear and tear on our machines. There is a reason ARGO has continued to strengthen the drivetrain to survive using a flat snowmachine belt surface that is difficult to turn and tgaf uses guides tgaf are hard on tire sidewalls. Lowering tire psi will gelp with shock-load type axke failures but causes other track tension related problems with the factory rubber track. One of many readons I dont like it.
I still build and use the steel bar channel track frequently but only use it on machines with 10/11” tires or narrower. I also add extra grousers and lengthen a little to limit stress. Steel can fatigue and develop cracks if abused with too much tension. More commonly you’ll see bent grousers from abusive conditions but occasionally some develop cracks. Other times they hold up great for a long time, just depends on the end user. But the 12” wide tires and heavier machines seeem to be more prone to bending steel grousers.
So for these machines I insist on solid through bolted UHMW grousers (I make them interchangeable with the steel grousers for previously built tracks too) so that these machines that put the most stress on the tracks (heavier, more distance between track belts/leverage on grousers, lower gearing, higher hp, tracks can ge run tight) do not and cannot break the track grousers (I still have never seen it happen). So for Avengers, Auroras, Centaurs, ect, An Elevated belt through bolted UHMW grouser makes for a maintenance free track that works everywhere and gives all the benefits of my favorite track style for Alaska. Both the steel channel and UHMW through-bolted do this, but a UHMW elevated belt track stands up to abuse. My material cost is more for the UHMW but it is what it is I guess.
As for axle damage with rubber tracks (or any tracks for that matter), my experience has been that lower/softer psi in tires does a lot to absorb unexpected shock loads. So does slowing down. Another reason I prefer the elevated belt track- You’ll automatically reduce your crawling speed by 25% and your track does not need to be tight (there are no guide tips to manipulate), so running very low psi is just fine, and with some of the newer rims, preferable. In fact it’s basically a run flat set-up.
Onlyonce- I happy to share info good and bad
