I am running a set of rubber tracks on my HDi. This is my second one. They do what nothing else does. This one came with higher gearing which is a huge mistake. I didn't order it that way but it is what it is. I have always had an issue with the track guides punching the bead off the tires occasionally. Usually the fronts. I started to run a higher tire pressure and that eliminated the problem. This last run however I found I had a flat. Second tire back. I found a small split in the sidewall. Do you think it's from higher pressure in the tire? Is there any reason I can't run an aftermarket tire? If yes which one is best? I know my tire guy is going to resist the idea of a patch and a tube.
Thanks
Thanks
