I've narrowed my choices down to either Carlisle AT 101's or Duro mud and sand tires. It's going on a hustler 900 hk with a 16 Ho motor and Whipper made splined axles geared down a hair. Any advice?
AT 101 or Duro's?
The duro's don't swim at all! I would go with at101's unless you have a designated swimming machine and designated mudding machine. If that's the case, find a better muddying tire than the duro's, like some vampires or executioners or anything with a better lug than the duro's.l like to buy stuff and no I don't do payments!
I would go with vampires they come in a 22", but you will have to get 9" wheels. It's worth the money spent to get some good bead lock wheels tho. They should work for occasional swimming and will perform a lot better in the mud and peat bogs.Courage Invites Critics
Here's the best price I have found on them.
Interco Vampire ATV Tires
RI sells 9" rims and Matt @ Mudd Ox might have them
Not sure what other options are out there for 9" rims with the correct bolt patternCourage Invites Critics
The biggest problem with those is that no one wants to ship them to ALaska for under $200. The carlisles i can get on amazone with free shipping. How can you tell if you have bead lock rims or not? I thought the ones i had were bead locks???Steven Untiet
If you already have 9" rims I wouldn't worry about if they have a bead lock or not, I was just sayin if ur goin to buy 9" rims ur better off buyin rims with a bead lock. Your stock rims are probably 8" tho I would assume so if u go with the at101's just use ur stock rims.Courage Invites Critics
The beadlocks are actual beads rolled into the rims, some are better than others but as long as there is one that's the key. Trailer rims (except those at recstuff.com) generally do not have a beadlock and are flat.
If your current rims have a indent rolled into them about 3/4" off the faces, you have bead lock rims.sigpic
Almost went with the 101's thru amazon because of the free shipping, but went with the Kenda Bear Claws thru amazon instead and got free shipping. I'm in Alaska. So not much swimming more peat bogs, trails and mud.
Haven't run them yet, should have the argo back together next week and a field test soon.
If you're concerned with tires spinning on the rims, drag racers use Permatex high tack on their rims and tires to prevent the slicks from moving on the rims. Google it for details.
If it's not raining anytime soon, I'll roll the tub out of the shop and take some pics of the tires.Last edited by KBSAK; 08-21-2013, 12:45 AM.
HI,
Bearclaw tires ###DONOT SWIM ###
THE REVIEW
Pro's
good to very good forward and reverse traction
The tires were only available in 6 ply good for puncture resistance
Negatives
Very Very bad at swimming ,so poor that any or even the slightest current in a river they would not work
Difficult to turn even after more than normal throttle and little more straight line speed prior to turning
Poor ride quality very stiff ride
Tire fitted to a good condition argo 1987 6x6 2-3 psi in ties
The tire u need to use, or similar is an all rounder eg a DURO HF255 v lug chevron etc [same as AT101 Carlisle ]
The Duro HF255 is an agricultural tire in the Duro cataloge
Remember the fitted size ,diameter is what matters .Many 22 inch tires are closer to 21 inch once fitted.
AS a side note I also have 26/12/12 duro hf255 chevron run at 2-3 psi on a swamp fox .The 22 11 8 versions are softer riding ,both are 4 ply
The Hf 255 review
Pro's
Very good universal tires
swim ok
dirt ok
sand ok
hard surface ok
soft surface ok
turning ability very good [does easily does not load up transmission ]
Better puncture resistance than a stock type tire [4ply Duro hf255 ] [Many OEM tires are 2ply although this trend is decreasing ]
Neg
The tire does not specialize in a particular condition
A 6 ply will have more puncture resistance
Remember many tires donot skid steer [high loads on transmission ]
tomo:
NB
U can always run a chevron v lug either in the swimming direction reverse or the forward direction for more dirt ability .I personally have never compared this .Last edited by Tomo; 08-21-2013, 05:53 PM.
