Price is right from Recstuff.com for 8' X 7" rims (trailer type 5 hole, DOT approved). They are welded all around, and weight the exact as the standard ARGO rim, 5.55LBS. But, a heck of a lot cheaper. Anyone buy a set of these wheels that can comment on them? Like, do they hold low pressure. I know they don't have the lube hole, but other than that what are the good, bad, or other issues?
Anyone using Recstuff 5 hole 8 X 7 wheels (rims)?
This should help:
There are other threads. However most are asking the same as me. There are even a couple of mounted tire pictures on the Recstuff wheels. But, not really a report on the wheels with new tires. Example: Are the beads good enough to hold 3.5psi? Some people say "no" on used tires, but that was not what I was asking. Really no real user's reports (just opinions) telling us if the bead is good on new tires after they have been in use a while.. Which is what I was asking. And still am.
The information you are looking for will still be just an opinion. Unfortunately there is no standard of measure for bead holding, and each brand/model tire will be different, along with different machines, driving style, and terrain will exert different forces on them.
If you can afford them, buy K-lock rims. If you can't, well, you will have to live with the rougher ride of more air pressure and/or the P.I.T.A. of a tire coming off the bead on occasion.
I have them on my racer. I have had no problem, but I only use it on the track. I did put used tires on them, but I also glued the tires to the rim with gasket sealant. It's a nice cheap option, however, I have k-locks for my max Iv and Attex tomahawk. Those are the machines that take a real beating on the trails.l like to buy stuff and no I don't do payments!
Finely, one real answer. "No problem on a racing track." What brand on bead sealant did you use?
Buggyman: Every answer is an opinion, and I value yours. However, one that really purchased the Recstuff wheels and installed new tires on them carries a lot more weight than a questionable opinion with no experience with the product, even if they are only used on a track.
Originally posted by shot410ga View PostFinely, one real answer. "No problem on a racing track." What brand on bead sealant did you use?
Buggyman: Every answer is an opinion, and I value yours. However, one that really purchased the Recstuff wheels and installed new tires on them carries a lot more weight than a questionable opinion with no experience with the product, even if they are only used on a track.l like to buy stuff and no I don't do payments!
Originally posted by shot410ga View PostI talked to Recstuff about these wheels. They are a bead lock wheel "J" style."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
