Originally posted by Buzz
View Post
A question for you track experts
Originally posted by Buzz View PostI believe the axles are about 1.25" longer. One direction the offset in rims (also approx 1.25") is added to the increased axle length, while in the other direction the offset in rim washes out the increased axle length.
Because the 10" wide tires already have a bonus 1" of clearance on either side of the rim centerline compared to a 12" tire, a couple things come to mind. With equal spacer widths, a 10" tire can run an inner belt that is 1" wider than a 12" tire running the same style, and both have the same amount of clearance.
If you were to simply put a 1/4" spacer on each axle, or stack a couple washers on each lug stud, and you were to use the longer axles and 10" wide frontier tires, then you could run a 4" inner belt (similar to what 12" tires do with 2.5" spacers), and you would have the same amount of clearance.
Hope that makes sense. 1.25" gained from longer axles, 1" gained (towards the machine) because of the narrower 10" tire, and .25" gained from your spacer of choice. In fact, you don't really even NEED the .25" spacer part, but it would be better.
Or you use the longer axles + standard 2.5" spacer and have clearance for up to a 6" inner belt.
Just a fun hobby my friend, and I enjoy it! The key is sharing information from you have learned..
With the new longer axles, re-using your standard 8" diameter argo rims and 2.5" argo wheel spacers, you can run a 6" inner belt.
You do give up some footprint by going from a single 8-wheel track to a set of quad tracks on the same machine. But, it is very easy to add track width, especially with the elevated belt style track, and it remains just as easy to skid-turn. Moving to a quad track is equivalent to running a 6-wheel track on an 8-wheel machine (track widths being equal apples to apples). The tracks are moved to the corners to evenly balance the weight distribution. You simply add a bit of width to the quad tracks to get your desired footprint back.
With an elevated-belt track, added width does not make it more difficult to skid turn, it only makes the machine wider and improves performance when the conditions require it. You still drive around skid-turning a track that the machine feels as only 10" wide, in your case
A full length 18" wide rubber track = 1422 square inches VS. Quad tracks @ 27" wide = 1420 square inches (winter use for both) roughly the same
A full length 14.7" wide track = 1161 square inches VS. Quad tracks @ 22" wide (10" touching the ground and skid-turning most of the time) = 1158 square inches (summer time use for both) roughly the same
It would be very easy to run for instance a 22" elevated belt quad track and then add a 5" winter kit to get adequate deep snow floatation similar to the argo rubber track. It would be just as easy to run a slightly wider winter kit to give you an advantage. All the while, it would take 25% less torque to drive and you would get the other added benefits of the elevated belt track design. And, I believe the redundant set up you're looking for. No track tuners required for channel tracks if a quad-track set up is used.
Hope that helps, and I would strongly recommend that the inner belt edge be beveled back to just outward of the grouser-guide so that the tires do not rub. I bevel the belt back to the inner backer washers.
Hope that makes sense!
NCT, this would be a very crude visual aid as to how I see the tire indexing work, speed would be a variant as the majority of the machine weight would be carried by the 1st and 2nd axles. I would also believe that with the larger tires on the outer ends any encountered debris, such as a large rock, would become an exaggerated force as the 2nd smaller tire would take a moment to pull the track over the encountered obstacle.
Should any of you guys feel I am off kilter here please let it be known as I would not want to misdirect anyone. I am no engineer by any means.
I think that the side load felt by the corner axles is more related to how tight the track is. Some tracks need to be tighter than others. If the length is too short, or the corner tires are overinflated, then the corner axles see additional side load. The center tires just don't seem to affect the track tension at all in my experience. Even if the center tries are significantly overdriven, the track sagging on the top of the track is directly related to the overall length that it was built to, the sizing of the front/rear tires, and the direction of travel
If the track is tight, sometimes you won't even see sagging on top of the track regardless of direction of travel or the position of the tires.
Either way, even with track tuners differences in the circumfrence of the front and rear tires must be scrubbed out. The ease at which the rear tire can scrub out this difference is directly related to 1) track tension and 2) how easily the tire treads can relieve themselves of the this load due to how they interact with the track or grouser surface. Some are more forgiving than others.
Or you do your best to get the rear tire as close to the same size as the front, and then "slightly" increased the size of the rear tire to as to protect the rear tensioner.
Having a track than is compatible with being a bit loose is helpful.Last edited by Buzz; 01-01-2017, 04:19 PM.
