Just my two cents.
Until there is a Consumer Reports or Gun Tests for both AATV's and Tracks for AATV's, I think that the possibility for a unbiased comparison for either AATV's or Tracked AATV's or tracks for AATV's will never be found. However, CDOVER73 is on to something, SHOTGUN made a good point, and I think that the post by JOHNF pretty much hits the nail on the head. Describe your locale, the terrain that you normally encounter that works or does not work with tracks, the machine that you have, and the tracks that you use. Then list the pros, cons as you see them and add any changes you might or have made to overcome obstacles. All that combined per post would really hit home.
I also have been doing "legwork" regarding tracks. And like CDOVER73, I have read nearly every track post on this forum looking for answers. Like some others, I live in an area where there are not a lot of "visible" AATV's so I have no one that I can go to to either see or ask about tracks. There is not even a local dealer. While Canada is just to our North, driving up there to ask questions is just a bit out of the question. However, if some of our "Northern friends" and others around the world might like to chime in like JOHNF did, it might be the start of something good. I know that tracks are not cheap. I just do not want to invest money into a set of tracks only to find out that the make/style I purchase will not work on my machine for my intended purpose. And as has been pointed out, with all the other variables, "one size is not going to fit all". So maybe the posts/threads might at some point be broken out or moved to sub threads such as tracks on Argos, MAX, etc.
