Hello, I'm looking to replace the tires on my Argo Conqest. I would really like to go with the new Argo 24" tires to gain some ground clearance, and be able to move decently in water. My concern is that I live in the badlands, and I don't know how they will hold up. Do any of you know if the 22'' Rawhide III's, or the 21" Rawhide Terra are truly that diameter, or do they vary in diameter. Thank You FDMT
True tire diameter
I think the 22's are close to 21-3/4, the 21's run smaller also, both of these tires are designed for 8" wide rims, mounting them on 7" wide rims will require more air pressure to keep the rim from hitting the ground.
I run III's on my Argo on Max rims with 1 psi, 1 psi on and Argo 7" rim created rim to ground contact (rim bead would contact inside of tire ground pressure as the tread would contour to ground surface) as the sidewall allowed compression from being pinched in too far.
III's are too wide for Argo plastic tracks.sigpic
